Ansaugspinne Formula 400
theuninvited
Beitragvon theuninvited » Samstag 2. August 2008, 09:53
Morgen beinand!
Eine Frage an die Spezialisten: Passt die Ansaugspinne vom SB auf den Formula 400 BJ77? Wenn nicht, wo sind die Unterschiede, wenn ja von welchen Baujahren? :?:
Dank und Gruß,
Daniel
Erik Boattail
Beitragvon Erik Boattail » Samstag 2. August 2008, 12:17
If you mean Small Block by SB, a 400 isn't a big block either.
In fact: Pontiac never had small/big blocks, dimensions of the blocks were all the same.
If it fits on a 326, it also fits on a 350, 389, 400 or 455 engine.
theuninvited
Beitragvon theuninvited » Samstag 2. August 2008, 14:16
Thank´s Erik!
My question was if the Manifold of a, for example 350 Small Block 1980 would fit my 400ciu.
I know that the Pontiac Blocks are all the same, but i don´t know if they are similar to the chevy SB or BB.... you know what i mean?
Regards,
Daniel
Erik Boattail
Beitragvon Erik Boattail » Samstag 2. August 2008, 14:19
Not really, is it in fact that your asking if a small block Chevrolet intake manifold fits on a Pontiac engine ?
If that's the case, the answer is no.
theuninvited
Beitragvon theuninvited » Samstag 2. August 2008, 14:54
Yes Erik, that was the question...
Thank you!
