Frage zu einem 3-Gang Schaltgetriebe von einem 67er Mustang mit 289er Motor:
Wie (wo) kontrolliert man Ölstand, welche Wechselintervalle, wieviel Füllmenge.
Ich kenn das Auto nicht - wurde nur telefonisch gebeten euch zu befragen.
Danke,
Jürgen.
Schaltgetriebe 67er Mustang
- SMOKUM
OILING SPECIFICATIONS
BREAK IN
Fill your Toploader with any quality 75W-90 gear lubricant until the oil level reaches the fill plug opening. ...
It should take approx. 2 quarts.
We recommend changing the gear lube for the first time between 500 and 1000 miles
to remove the grease used to pack the needle bearings that has dissolved, Permatex, break in metal, glass beads etc.
We use several new parts in our transmissions and they will seat in with each other during the break in period.
It is not uncommon to see very fine metal on the magnetic drain plug when you drain the oil the first time.
MAINTENANCE
We recommend changing the gear lube every 20-25,000 miles in normal street driving applications. If you have higher
than stock horsepower or drive your car aggressively you should change the gear lube every 10-15,000 miles.
For stock type applications 75W-90 should work well in all climates. In heavy duty applications
and hot climates 80W-140 will work best.
Na BITTE ! - SMOKUM
BREAK IN
MAINTENANCE
Na BITTE ! - SMOKUM
Let the good times roll !
