bigred
bigred
Beitragvon eric1617 » Donnerstag 11. September 2014, 06:38
grant
Beitragvon grant » Donnerstag 11. September 2014, 08:56
interessantes Ding!
marvin
Beitragvon marvin » Donnerstag 11. September 2014, 09:18
Aber eigentlich nicht - auf diesem Weg - notwendig.
Die Australier haben auf konventionellem Weg über 300 PS aus den /6 geholt. Das Potential dieses 6-bangers war / ist beachtlich.
Mit der Hyper Pak Option hatte man schon 1960 deutlich über 200 PS:
The Hyper Pak was a parts package made available from 1960 through 1962 at Chrysler Corporation dealer parts counters. The parts were made available to comply with the regulations of sanctioning bodies for racing events in which Valiants had been entered by factory-backed teams: All parts used had to be "stock" parts, the definition of which meant that they were available through normal factory parts channels. The Hyper Pak consisted of a very-long-ram intake manifold meant to accept a Carter AFB 4-barrel carburetor, the AFB carburetor itself and an appropriate air cleaner, dual (front-3 and rear-3) cast-iron exhaust headers, a large-diameter exhaust Y-pipe to connect to these dual cast-iron headers, a larger muffler, a 276°-duration camshaft with appropriate valve springs and pushrods, a heavier-duty clutch, a manual choke control, a starter motor modification template and, in the full-race version of the package, high-compression pistons designed to increase the engine's compression ratio to 10.5 from the stock 8.5. The Hyper Pak was recommended for installation only on vehicles equipped with manual transmissions, for the camshaft was of such characteristics that a high idle speed was required to prevent engine stall-out. The Hyper Pak was primarily intended for competition driving, its road manners involving rough idling and poor cold-engine driveability, a high power band and poor fuel economy. But, in competition events, it proved unbeatable. Eight factory-backed Valiants entered the 1960 NASCAR compact car race at Daytona Beach, and humbled the competition; the Valiants came in first through eighth. After a similar performance the following year, the race was dropped.
...aber der slant 6 overkill gelang den Aussies:
The 1972 E49 Charger was another significant move forward, and not just because it was the first to get a four-speed manual gearbox (from Borg-Warner). The E49 pushed the 265 Hemi engine to a full 302 hp, and had the quickest acceleration of any Australian production car - 14.4 seconds in the quarter mile, six seconds and change 0-60, respectable even when compared to American big-blocks or 1990s sport compacts.
