38er CHEVY MASTER DELUXE Projekt(Aufgabe)
Angebote über Autos der Marken (US)Chevrolet, Buick, Pontiac, Cadillac, Hummer, GMC, Oldsmobile - ausschließlich für eigene private Anzeigen
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 11:08
Hallo Leute
ich denke drüber nach, eines meiner Projekte aufzugeben..
hätte jemand Interesse (würde aber nur das ganze Paket verkaufen)
ENGINE (NEU)
Chevrolet Performance Complete 350 HO Deluxe Long Block Crate Engines 19210008[/b]
"Chevrolet Performance delivers its lowest priced performance deluxe complete crate engine in the form of a 350 cu. in. HO (high-output) with approximately 9.1:1 compression, 330 hp at 5,100 rpm, and 380 ft./lbs. of torque at 3,700 rpm. Dressed to impress with chrome valve covers and front timing cover, the powerplant will look great between the fenders of your favorite street rod, muscle car, or grassroots racer.
Stamped steel self-aligning rocker arms are used for reliability. Aluminum dual plane with EGR-capable Vortec-style intake manifold with a Holley 600 cfm vacuum secondary with electric choke help feed the engines. Spark plugs and HEI distributors are included—as well as standard 8 in. balancer and 12 3/4 in. flexplates; chrome air cleaner; and standard cast aluminum thermostat housings with driver side hose connection and a 180 degree thermostat. This crate engine kit also includes the oil filter, oil filter adapter, PCV valve, PCV hose, oil dipstick, and tube.
GETRIEBE (NEU)
TCI Super StreetFighter Transmissions 311005
TCI Super StreetFighter transmissions bridge the gap between the StreetFighters and full Competition series transmissions. Like the StreetFighter units, these are equipped with 100 percent tested, manual/automatic valve bodies. That means that most units allow you to manually shift the vehicle into each gear change or, by placing it in the drive position, remain fully automatic. In either mode, you get a racetrack shift that bangs through the gears and shaves time off your ETs. When you use the manual gear selection feature, the Super StreetFighters upshift and downshift right when you move the lever, with no lag or governor override. When you select the normal drive position, the transmissions retain positive automatic shifts, for the ease of driving you look for in an automatic transmission.
VORDERACHSE INKL SCHEIBENBREMSEN (NEU)
37-48 CHEVY MUSTANG Vorderachse
CHASSIS
INNENAUSSTATTUNG (komplett neu) inkl. Türplatten
KAROSSERIE (sandgestrahlt und epoxydgrundiert)
WAGERL / KAROSSE
Räder / NEU
Kleinteile
Alfred
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 11:10
Alfred
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 11:14
irgendwie nimmt er keine Bilder ???
Alfred
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 11:45
Alfred
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 11:47
sieht da irgendwer Bilder ???
Alfred
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 11:57
Ich sehe nix... komisch
Alfred
Beitragvon ami74 » Mittwoch 9. Dezember 2020, 12:46
bin schon auf die einzelgenehmigung gespannt mit dieser motortechnik und so weiter :)
chargerfred
Beitragvon chargerfred » Mittwoch 9. Dezember 2020, 13:07
Naja einzelgenehmigung Etc wird schwierig...klar
Aber der der sich so ein Projekt antut kennt auch die Randbedingungen
Alfred
chargerfred
Beitragvon chargerfred » Donnerstag 10. Dezember 2020, 07:25
NIEMAND Interesse ???
Alfred
1960coupe
Beitragvon 1960coupe » Donnerstag 10. Dezember 2020, 07:33
es fürchtet sich jeder vom vermutlichen Preis :-)
chargerfred
Beitragvon chargerfred » Donnerstag 10. Dezember 2020, 08:11
Keine Angst, ich denke das würde eine faire Geschichte werden...
Die Neupreise der Komponenten sind klar
aber ich möchte da kein Geld verdienen
Alfred
chargerfred
Beitragvon chargerfred » Freitag 8. Januar 2021, 20:34
UP !
Einmal probier ichś noch
Eventuell hat ja wer über die Feiertage nachgedacht und jetzt doch interesse ...!
Würde mich freuen
Ps: die Innenausstattung ist nicht „neu“ sondern neu vom sattler ...gemacht
Alfred
f100
Beitragvon f100 » Samstag 9. Januar 2021, 15:58
was willst ohne motor getriebe
chargerfred
Beitragvon chargerfred » Samstag 9. Januar 2021, 16:18
F100:
Hast PN
Alfred
chargerfred
Beitragvon chargerfred » Freitag 31. März 2023, 09:39
ich probiers nochmal
ev wer Interesse ?
mag das Projekt nicht mehr machen
alles noch vorhanden
Alfred
