meine motornummer + kopfnummern identifizieren ?
hier motorplocknummer:................ DIVE - 6015-A2E
köpfe (aus der smogzeit ?):......................DV3E-A2A
danke für hilfe
motornummer + kopfnummern identifizieren !?
- mcnitro
http://www.ford-trucks.com/forums/archi ... block%20id
http://www.clubhotrod.com/t13334.html
das ist alles was dr.google so auf die schnelle findet. vielleicht hilfts
- cenzi
- Werbepartner
cenzi hat geschrieben:also ohne hier zu googlen würd ich sagen 429/460er block, 2-bolt mains, ab 72. köpfe mit großen brennräumen mitte 70 cirka, ventile normalgroß.
irgendwas aus einem lincoln oder großem ford. eventuell truck.
VIN
yep - ist eh unter den links so zu entnehmen denke ich
just aqired 460 block and heads.
block id is DIVE-6015-A2E, and head id is D3VE-A2A
"I need some help finding out some info an a set of 429 heads (DV3E A2A). Anyone tell me anything about them"
he most common carbureted head casting numbers are: C8VE-A, C9VE-E, D0VE-A, D0VE-C, and D3VE-A2A.
All the above heads have 2.08 intake valves and 1.65 exhaust valves.
C8VE-A, C9VE-E, D0VE-A, & D0VE-C all have identical architechure, are completely interchangable and have 75-77cc combustion chambers. These are the most popular factory heads for performance applications.
D3VE-A2A's have a 96cc combustion chamber and a different valve train assembly that is not interchangable between it and the other heads. They can be made to work well but require more prepping.
Ther is also the D0OE-R Cobra jet heads (nice but rare) and the D2VE-AA heads (JUNK).
The heads and valve trains are all swappable between the blocks.
There is no such thing as 2-bbl and 4-bbl heads...they are the same thing.
I have a set of D3VE heads on my boat and the motor makes over 550HP.
